UbidotsMicroESP8266 will not update the data pls help
DHT dht(DHTPIN, DHTTYPE);
void setup(){
    delay(10000);
    dht.begin();
    // client.wifiConnection(WIFISSID, PASSWORD);
    WiFi.begin(WIFISSID,PASSWORD);
    Serial.println(WIFISSID);
    Serial.print("WiFi.status=");
    Serial.println(WiFi.status());
void loop(){
    float value = dht.readTemperature(true);
    float value2 = dht.readHumidity();
    client.add("temperature1", value);
    client.add("humidity1", value2);
    client.sendAll(true);
    Serial.println("Ubidots data");
    Serial.println("temperature: "+String(value));
    Serial.println("humidity: "+String(value2));
    Serial.println(" Going to Sleep for a while !" );
    delay(30000);
This code connects fine but does not update the variables in Ubidots.
Here is the serial monitor response:
=>temperature1:75.20000,humidity1:34.00000,
POSTING YOUR VARIABLES
Ubidots data
temperature: 75.20
humidity: 34.00
I have the same problem!
