[TO BE SOLVED] Sometimes receive 0 from switch or slide
Hi, i´m using UbidotsGetValue example, and everything is ok but sometimes i receive an incorrect value=0, one or two of every 10 values are wrong (=0). It´s happening to me with switch or slide variables. I want to know how can i fix that.
Thanks and sorry for the english
Hello @pxyco,
Can you let me know which library are you using?
I´m using the library from: https://github.com/ubidots/ubidots-esp8266
Thanks for report the inconvenience. I’m going to check the library in order to reproduce the issue.
