[SOLVED] Trying to send Non-GPS context with a variable
All,
I want to send non-GPS context with a variable and I believe the format would look like this:
    "Moisture": "{{Moisture}}",
    "Watering": {
        "value": "{{Watering}}",
        "context": "{{status}}"
    "SoilTemp": "{{SoilTemp}}"
I have tested a JSON body for this structure and believe this is valid:
{"SoilTemp":"19","Watering":{"value": "0", "context": "Oops"},"Moisture":"516"}'
but when try to send using a curl command I get a response that I cannot figure out:
{"watering": [{"status_code": 400, "errors": {"context": ["'Oops' value must be a dict."]}}], "soiltemp": [{"status_code": 204}], "moisture": [{"status_code": 204}]}
I could not find a reference to error code 204 in the response code documentation and I could find no reference to ""'Oops' value must be a dict."". Can you please tell me what I am doing wrong.
Thank you for any help you might be able to provide.
Chip
Hello @chipmc,
As I can see on the requests you are building in a wrong way your context, the context is a key-value dictionary, so your payload should be something like this:
{"SoilTemp":"19","Watering":{"value": "0", "context": {"key1":"Oops"}},"Moisture":"516"}' https://things.ubidots.com/api/v1.6/devices/{DEVICE_LABEL}
So please try with this command:
curl -X POST -H 'Content-Type: application/json;' -H 'X-Auth-Token: {PUT_HERE_YOUR_TOKEN}' -d '{"SoilTemp":"19","Watering":{"value": "0", "context": {"key1":"Oops"}},"Moisture":"516"}' https://things.ubidots.com/api/v1.6/devices/{PUT_HERE_YOUR_DEVICE_LABEL}
Thanks so much for report the missing response code, we just updated the documentation, in a few minutes is gonna be available for the users.
@mariahernandez,
Thank you for taking a look. I see what you are talking about now but the JSON you requested I put into the curl request is not passing muster.
Ubidots is giving me this response: {“detail”: “JSON parse error - Expecting ‘,’ delimiter: line 1 column 82 (char 81)”}
I have also tried the JSON payload in Rick K’s tester and I is not valid. Are we missing a comma? If so, where?
Thank you for your help,
Chip
@chipmc,
Sorry for that, I missed a quote into the command. Please can you try again? The command is already modified and tested.
@mariahernandez,
I was able to get it to work and was able to upload the datapoints, getting the 201 response code.
Please see the cross-linked post on Particle. Even though the data has been uploaded, it is not showing up under “context” for the Watering variable. How do I display this data?
Thanks, we are making progress!
Chip
@chipmc,
Regrettably I’m not able to reproduce your issue, is working properly on my side:
Keep in mind that with the payload provided, the only variable with context data is “Watering” so that is the one that you should check. Can you try again?
@mariahernandez,
I tried again and it worked. Thank you!
Chip
