[SOLVED] No response from Switch
I setup a switch in the dashboard. When I turn the switch on and off I am not getting a response on the serial monitor
IP address:
192.168.2.81
entra
Attempting MQTT connection…connected
Subscribed to:
/v1.6/devices/roof-switch/switch/lv
As you can see I have a MQTT connection
client.begin(callback);
pinMode(4,OUTPUT);
client.ubidotsSubscribe(“roof-switch”,“switch”); //Insert the dataSource and Variable’s Labels
if(!client.connected()){
client.reconnect();
client.ubidotsSubscribe(“roof=switch”,“switch”); //Insert the dataSource and Variable’s Labels
Greetings @flightman49 , I see an error inside your loop function, in this line:
client.ubidotsSubscribe("roof=switch","switch"); //Insert the dataSource and Variable's Labels
you have as device label “roof=switch”, you cannot use special characters, your device label should be something like “roof-switch”. Keep in mind that your device and variable to subscribe must have been created previously at Ubidots.
I have to be more careful. The switch works now
Thank You
