[SOLVED] How to integrate Ubidots with a Mobile Device
Hi Group,
Any ideas out there how can i relate a ubidots project on a mobile device ?
Much thanks …
Hi Omer,
Ubidots provide a Java library you can use in your Android application, you can see an example of how is it used in this tutorial; if you want to use another library or use another platform in which Ubidots hasn’t build a library for it, you can also use our REST API endpoints to retrieve the information you need.
Hope this helps.
