[SOLVED] Getvalue problem
why does my variable attached to a get value keep resetting to -340282336?
sometimes it will run for minutes/hours before it resets on its own.
My setup is a particle Photon there is no coding that would change the value.
has anyone else seen this?
thanks steve
Dear @murmsk,
Some of our libraries uses that number to notice that there was an error during a POST or GET request, if you are using one of them just follow the examples provided to know how to treat with that error constant.
If you are not using any of our libraries, I would advise you to check how your device handles errors during the requests creation and posting.
error checking is easy enough . Thanks…since error checking is built in to the examples I assume that these types of errors are common place.
s
Greetings @murmsk,
to return an error value or flag does not mean that errors are ‘common’, any routine firmware should always have a way to notice that something went wrong, i.e the Arduino official web client returns ‘-1’ if there is something wrong during a TCP packet reception or sending, and our libraries simply extends these kinds of alerts managing them in an global variable equals to the most negative int value (aka -340282336).
If you are using your project for business purposes, I strongly advise you to develop your own firmware to fit your project’s needs as our libraries are intended for being the starting point but not the final one, and as such, we need to generalize several stuff (like errors notifications) in order to extend the library’s functionality to most of the general use cases.
