[SOLVED] Getting Value '0' from a Slider
Hi everyone ,
I’m using Ubidots Library for Arduino Ethernet-shield.I’ve been dealing with a Problem about Slider Widget.The Value i get from slider is always ‘0’ .
int a=client.getValue(SliderID) – I also tried with float but i got the same result.
What may cause this Problem ? If you have any solutions for that it would be great.
Thanks in advance.
Hello @mubuca95,
Following the examples you have to get the value as a float. I just made a test and I’m not able to replay your issue. I’m using the sample code to get a value from ubidots provide on the library. Please verify if is the same that are you using, also verify the connectivity of the shield.
#include <Ethernet.h>
#include <SPI.h>
#include <UbidotsEthernet.h>
#define ID  "Variable_ID_here"  // Put here your Ubidots variable ID
#define TOKEN  "Ubidots_Token_here"  // Put here your Ubidots TOKEN
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(172, 17, 0, 1);
void setup(){
      Ethernet.begin(mac, ip);
void loop(){
    float value = client.getValue(ID);
    Serial.print("Final value: ");
    Serial.println(value);
As you can see on the image I’m able to get the slider values without any issue:
I hope this would help you.
Best Regards,
