[SOLVED] Can I use ESP8266 using MQTT without connection manager
On mi EPS8266 I want to use the WiFiManager to connect with a WiFi and the subscribe to a variable via MQTT. I
Is this possible? Because I saw that most of the Ubidots APIs need to handle the connection in order to work.
Is any example if it’s possible?
I already connect with Ubidots using REST client and API client.
Link: https://github.com/tzapu/WiFiManager
You can use the Ubidots ESP library for MQTT:
You should pass the SSID and PASSWORD using Wifi Manager instead of define them as we made for the examples.
Thanks, it works perfect!
How did you code it ?
this is how i did it ,
  char WIFINAME[40];
  char WIFIPASS[40];
  wifiManager.getSSID().toCharArray(WIFINAME, 40);
  wifiManager.getPassword().toCharArray(WIFIPASS, 40);
  client.ubidotsSubscribe("zafiro", "GeoPosition"); //Insert the dataSource and Variable's Labels
  client.begin(callback);
i have not wifi response.
