[SOLVED] Arduino/Genuino MKR1000
Using Ubidots with MKR1000 works great, after small change in ubidots-arduino-wifi-master:
UbidotsArduino.h:
Change #include <WiFi.h> to #include <WiFi101.h>
That’s it.
@JLeib
Great! Yeah i was watching this special device and its libraries are too similar to Arduino WiFi shield librariees. thank you very much for your contribution.
Metavix
i have tried and it keeps failing during verify here is my code, using the MKR1000 board
#include <UbidotsArduino.h>
# include <SPI.h>
# include <WiFi101.h>
#define ID ""
#define TOKEN ""
char ssid[] = "";
char pass[] = "";
int status = WL_IDLE_STATUS;
int value = 100;
void setup(){
  while (status != WL_CONNECTED){
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(10000);
void loop(){
  client.add(ID, value);
  client.sendAll();
include SPI.h
include WiFi101.h
include UbidotsArduino.h
Hi David,
  1. please check your ssid and password to connect to your WLAN:
    needs to go here:
    char ssid[] = “”;
    char pass[] = “”;
  2. please check your Ubidots-Token:
    Needs to go here: #define TOKEN ""
  3. please check you Device/Source-ID of the Ubidots-Variable you defined on the web-page:
    Needs to go here: #define ID ""
  4. Be shure to change to #include <Wifi101.h> in UbidotsArduino.h
Check out the Arduino code-generator on the Ubidots-page
Cheers Juergen
i omitted that information since this is a public forum. i do include in the code. i have used the code generator through ubidots. i recieve the following error message
"Arduino: 1.6.11 (Mac OS X), Board: “Arduino/Genuino MKR1000”
In file included from /Users/descobar/Documents/Arduino/sketch_newUbidots/sketch_newUbidots.ino:3:0:
/Users/descobar/Documents/Arduino/libraries/ubidots-arduino-wifi-master/UbidotsArduino.h:63:23: error: ‘dot_t’ has not been declared
void getValueInfo(dot_t* dot); // Function added by Dr. Juergen Leib
exit status 1
Error compiling for board Arduino/Genuino MKR1000.
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
@descobar3d try with the new version of the library sir.
Metavix
Thank you! problem resolved!
