[SOLVED] Slider doesn't change variable
Sometimes when I change the value of a slider, the underlying variable isn’t changed. This even happens when the internet connection is fully reliable. Any idea what causes this?
Hi @paultjuh,
This behavior can happen if you release the click out of this frame, however we are looking how to make this slider more friendly.
kath :grinning:
That method works most of the time indeed, but not always. Also the step setting doesn’t work correct when using it with the mouse.
