[SOLVED] Resource responseed not found
Hello: I have an error in my code after 10-20 minutes I run my python script. This is the script:
#!/usr/local/bin/python3.5
import RPi.GPIO as GPIO
import serial
import rs485
import time
from ubidots import ApiClient
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(24, GPIO.OUT, initial=GPIO.LOW)
api = ApiClient(token='')
port = serial.Serial(
  port='/dev/ttyAMA0',
  baudrate = 115200,
  rtscts=True,
  timeout=0)
rs485 = rs485.SerialWrapper(port)
while True:
time.sleep(240)
if rs485.update():
    msg = 0
    packet = rs485.getPacket()
    msg = bytearray(packet)
    if msg[0]==3:
      hum   = msg[1]
      press = msg[2]*100 + msg[3] + msg[4]/10
      temp  = msg[5] + msg[6]/10
      print(temp,press,hum)
      api.save_collection([
      {'variable': '57556d2876254208bf20b2c3', 'value': hum},
      {'variable': '57556d1e76254208bf20b2a6', 'value': temp},
      {'variable': '57556d16762542084bf0f9bb', 'value': press}
    elif msg[0]==2:
      tempin  = msg[1] + msg[2]/10
      tempout = msg[3] + msg[4]/10
      print(tempin,tempout)
      {'variable': '57556c9676254203723fddea', 'value': tempin},
      {'variable': '57556ca3762542043aaa720e', 'value': tempout}
and this is the error:
  File "./rs485_prog.py", line 45, in <module>
  File "/usr/local/lib/python3.5/site-packages/ubidots/apiclient.py", line 148, in wrapped_f
    return fn(self, *args, **kwargs)
  File "/usr/local/lib/python3.5/site-packages/ubidots/apiclient.py", line 491, in save_collection
    response = self.bridge.post(path, data)
  File "/usr/local/lib/python3.5/site-packages/ubidots/apiclient.py", line 108, in wrapped_f
    response = fn(self, *args, **kwargs)
  File "/usr/local/lib/python3.5/site-packages/ubidots/apiclient.py", line 97, in wrapped_f
    raise error
ubidots.apiclient.UbidotsError404: Resource responseed not found:
Could you help me to understand why this happens?
Francesco
Hello Francesco @cicciotalotta,
The error is because we couldn’t find the variable or Device you are trying to access. Verify your token and item’s ID.
To know more about the response codes please reference to this link.
Best Regards,
Hello, Thank you for the reply.
Today I got this error:
  File "./rs485_prog.py", line 46, in <module>
    raise error
ubidots.apiclient.UbidotsError500: An Internal Server Error Occurred.
I think is a Ubidots server error again.
Francesco
Yes, the response code 500 is a server error… At the moment we’re are improving the platform to add new features to our users, that’s why you have that inconvenient.
Best Regards.
