[SOLVED] Python with Edison Board - ERROR from ubidots import ApiClient
Hello guys,
Im trying to connect my edison board to the ubidots cloud with python. However when I try to import the ApiClient
File “”, line 1, in
File “/home/root/ubidots.py”, line 10, in
ImportError: cannot import name ApiClient
Can someone help me ?
Thanks in advance,
Hi @andrelmbraga,
Could you show me your code please ?
Catalina M.
I followed the tutorial in ubidots website
https://ubidots.com/docs/devices/intelEdison.html#setup
import time, mraa
#Connect to Ubidots
for i in range(0,5):
try:
print “Connecting to Ubidots”
api = ApiClient(token=‘d195c0044fcasdfdf9dsfab9d653af3’) # Replace with your Ubidots Token here
break
except:
    print "No internet connection, retrying..."
    time.sleep(5)
Assign analog pins
a0 = mraa.Aio(0)
a1 = mraa.Aio(1)
Read analog pins and send values to Ubidots
while(1):
try:
api.save_collection([{‘variable’: ‘Put_Here_Your_Variable_ID_1’,‘value’:a0.read()}, {‘variable’: ‘Put_Here_Your_Variable_ID_2’,‘value’:a1.read()}])
except:
print(“Couldn’t send data.”)
continue
Looks like the Ubidots library isn’t installed in your system. Could you try installing it again and posting the output of the action?
pip install ubidots
If you don’t see any error message in the output, try executing your program again, please.
Have a great day :grinning:
