[SOLVED] Problem with setting Y-axis manually to zero, reverts to Auto
I have a timeserie graph widget showing wind direction in the dashboard. The valid variable values are 0-360. Now I have set max value to 360 and min value to 0 in the widget Y-axis. Still, the min will fall back to auto and the Y-axis starts at 182, but it ends at 360. I have 500 data points in widget and shifting.
Hope for solutions.
/Joakim
Hello Joakim,
Thanks for the report and sorry for not answering soon.
This was fixed and deployed a few weeks ago. Is your widget now behaving as expected?
Thanks again for the report!
Thanks I haven’t seen any problem for a while now. So it is probably fixed. :slight_smile:
/Joakim
