I am doing a temperature sensing wireless device using arduino yun. I am using the API POST function to post data to Ubidots. I tested the code using sample values and it is working. But when i change the value to a variable, no data is posted in Ubidots. I modified the program code and implemented an increment code for simplicity. The basic is the same, I want to post a changing value using API POST.
BTW I got this code from https://www.youtube.com/watch?v=QdT38fpm924
The following is the full code for posting value.
include Process.h
float changingval = 0;
Bridge.begin();
SerialUSB.begin(9600);
while (!SerialUSB);
changingval = changingval + 1;
Serial.print(changingval);
runCurl();
delay (2000);
void runCurl() {
Process p;
p.begin(“curl”);
p.addParameter(“-X”);
p.addParameter(“POST”);
p.addParameter(“-H”);
p.addParameter(“Content-Type: application/json”);
p.addParameter(“-d”);
p.addParameter(“{"value" : 27}”);
p.addParameter(“http://things.ubidots.com/api/v1.6/devices/Home-Sensing/temperature/values?token=X5m8TUi5w6Iu7SAN2toMsBYxGyuJHR”);
p.run();
while (p.available() > 0) {
char c = p.read();
SerialUSB.print(c);
SerialUSB.flush();
When posting with sample value, the post function is working.
p.addParameter("{\"value\" : 27}");
But when I changed to variable, the code is not working.
p.addParameter("{\"value\" : \"changingval\"}");
Please help me troubleshoot my problem.
Thanks in advance.
