[SOLVED] Latitude/Longitude
Quick question: I want to pass on GPS data as one single variable, and then using the Auto-location option to have it live-update on the map.
However, what format is recommended for this? Would a format such as 49.5473, -126.4312 (while named ‘gps’) be okay? Does it also matter which data-type is used for this?
Hardware is the Particle Electron 3G. Current way of sending data is as follow:
{“lat”: “%.04f”, “lon”: “%.04f”} , creating two seperate variables
Yes,
You should be send that data in the context field here and example https://github.com/ubidots/ubidots-particle/blob/master/examples/UbidotsSendValuesWithContext/UbidotsSendValuesWithContext.cpp
For more information about the position you can follow this article:
http://help.ubidots.com/user-guides/change-default-device-location
Gustavo.
Thanks, works great!
However I noticed this:
sprintf(context, “lat=1.2343$lng=132.1233”);
However, instead of a pre-defined number I would like to put my own lat/lng variables in here. how should I pass that on?
Greetings,
the sprintf() is a special C function to create char arrays, simply store your latitude and longitude inside two variables and add it to the char array. You can reference to the usage of sprintf() here.
I tried this:
    float value1 = analogRead(A0);
    char context[25];
    sprintf(context, "%.2f, %.2f", lat, lng); //Sends latitude and longitude for watching position in a map
    Serial.println(context);
    ubidots.add("gps", value1, context);  // Change for your variable name
    ubidots.sendAll();
The serial prints 49.19, -123.10 but the Ubidots variable is no longer updated anymore. When I do sprintf(context, “%.2f %.2f”, lat, lng) (note the lack of comma) the data sends, but doesn’t update the location on the Dashboard.
Nevermind, I think I solved it. If anyone reading this wonders how, this code should do the trick:
char context[25];
sprintf(context, "lat=%.2f$lng=%.2f", lat, lng); //Sends latitude and longitude for watching position in a map
ubidots.sendAll();
Thanks for your feedback, much appreciate it!
