How to get more one data android studio
hii, i have some problem to get 2 data in android studio. i want get data soil and distance, but i just get data soil in my android app. And distance data not show how to fix it ?
this is code from android
private static final String SOIL_LEVEL = “Soil”;
private static final String DISTANCE_LEVEL= “Distanace”;
private TextView sensorSoil;
private TextView sensorDistance;
private BroadcastReceiver mSensorSoil = new BroadcastReceiver() {
    @Override
    public void onReceive(Context context, Intent intent) {
        int level = intent.getIntExtra(SOIL_LEVEL, 0);
        sensorSoil.setText(Integer.toString(level) + "%");
        new ApiUbidots().execute(level);
private BroadcastReceiver mSensorDistance = new BroadcastReceiver() {
    @Override
        int level = intent.getIntExtra(DISTANCE_LEVEL, 0);
        sensorDistance.setText(Integer.toString(level) + "cm");
@Override
protected void onStart() {
    super.onStart();
    registerReceiver(mSensorSoil, new IntentFilter());
    registerReceiver(mSensorDistance, new IntentFilter());
@Override
protected void onStop() {
    unregisterReceiver(mSensorSoil);
    unregisterReceiver(mSensorDistance);
    super.onStop();
public class ApiUbidots extends AsyncTask<Integer, Void, Void> {
    private final String API_KEY = "your api";
    private final String SOIL_ID = "id1";
    private final String DISTANCE_ID="id2";
    @Override
    protected Void doInBackground(Integer... params) {
        Variable soilLevel = apiClient.getVariable(SOIL_ID);
        Variable distanceLevel= apiClient.getVariable(DISTANCE_ID);
        soilLevel.saveValue(params[0]);
        distanceLevel.saveValue(params[0]);
        return null;
Hello, have you tried to get your distance and soil values individually? If you can retrieve successfully them, then the issue is in the way as you store them, I see that you save them at the same index inside the params[] array, maybe there it is your problem.
i finish to try it but my data value not show for soil and distance
