Cant send arduino values to ubidots (error pop up)
Arduino: 1.6.8 (Windows 7), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createTempFile(File.java:2024)
at processing.app.BaseNoGui.saveFile(BaseNoGui.java:1087)
at processing.app.SketchCode.save(SketchCode.java:222)
at processing.app.SketchData.save(SketchData.java:165)
at processing.app.Sketch.save(Sketch.java:595)
at processing.app.Editor.handleSave2(Editor.java:2244)
at processing.app.Editor.handleSave(Editor.java:2224)
at processing.app.Editor.handleRun(Editor.java:1921)
at processing.app.Editor.handleRun(Editor.java:1915)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:344)
at java.awt.Component.processMouseEvent(Component.java:6532)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6300)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4891)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4713)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4522)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Access is denied
In file included from C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_199888\UbidotsSaveValue.ino:5:0:
C:\Users\admin\Documents\Arduino\libraries\ubidots-arduino-wifi-master/UbidotsArduino.h:63:23: error: ‘dot_t’ has not been declared
 void getValueInfo(dot_t* dot);  // Function added by Dr. Juergen Leib
C:\Users\admin\Documents\Arduino\libraries\ubidots-arduino-wifi-master/UbidotsArduino.h:40:16: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
#define SERVER “things.ubidots.com
C:\Users\admin\Documents\Arduino\libraries\ubidots-arduino-wifi-master/UbidotsArduino.h:60:41: note: in expansion of macro ‘SERVER’
 Ubidots(char* token, char* server = SERVER);
C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_199888\UbidotsSaveValue.ino:16:21: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_199888\UbidotsSaveValue.ino: In function ‘void loop()’:
C:\Users\admin\AppData\Local\Temp\arduino_modified_sketch_199888\UbidotsSaveValue.ino:50:29: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     client.add(ID, value);
Multiple libraries were found for “UbidotsArduino.h”
Used: C:\Users\admin\Documents\Arduino\libraries\ubidots-arduino-wifi-master
Not used: C:\Program Files\Arduino\libraries\ubidots-arduino-wifi-master
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
@junada95 its urgent
@ayshwarya Hi,
What Arduino IDE Version are you using?
Also you can do a quick search on google with this problem:
So, It seems to be a permissions problem. Check that you have permissions for use the port and the IDE too.
Gustavo.
im getting this error and cant seem to fix it. using IDE 1.6.11
Hi @ayshwarya
You have an error here:
There are two definitions of same library you need to delete one of both,.By the way change the name of the “ubidots-arduino-wifi-master” to “ubidots-arduino-wifi”
Metavix
