Build error while using ubidots C api
I am trying to run sample program in Ubidots C api. While building the C program error is “F:\CCS_workspace\include\curl\curlbuild.h”, line 122: fatal error #5: could not open source file “windows.h”
any help is appreciated. Let me know if u need any more details.
@woakas @juanda95 @ubidots
@k413 what compiler are you using?
@Metavix used cross compiler specific for an IoT gateway board…
i tried with gcc and program works…
but the IoT gateway board is ARM based and gcc compiled code doesnt work on it…
@k413 that error is an error with a library of windows, and it is like a you don´t have permissions, you could try run as administrator.
Metavix
