[SOLVED] Arduino GPRS Send one value not working
I used the same code as given in http://ubidots.com/docs/devices/gprs.html#send-one-value-to-ubidots. The serial monitor shows an error message and that error message goes on iterating.
Response of GPRS:
Error with AT+CSQ
Response of GPRS:
No HTTP to close
{“value”: 10.000}
Response of GPRS:
Error with AT+HTTPINIT. Reset the Arduino, will you?
@rahulbaburaj could you post here your code?
by the way, please see if you have soldered the pad JP of GPRS Shield. it is to turn on/off the GPRS shield using code, you could find that pad near pin 9.
If you don’t want to solder it then please press the power key for about 2 seconds to power up or power down.
Metavix
#include <UbidotsArduinoGPRS.h>
#include <SoftwareSerial.h>
//Serial Relay - Arduino will patch a
//serial link between the computer and the GPRS Shield
//at 19200 bps 8-N-1
//Computer is connected to Hardware UART
//GPRS Shield is connected to the Software UART
#define TOKEN "XZRXTOKENl"  // Replace it with your Ubidots token
#define ID1 "577b7af6762542411a48327" // Replace it with your Ubidots' variable ID
#define APN "internet"
#define USER ""  // If your apn doesnt have username just put ""
#define PASS ""  // If your apn doesnt have password just put ""
#define VARIABLE_NAME "sensor1"
SoftwareSerial gprs = SoftwareSerial(7, 8);
SoftwareSerial *GPRSSerial = &gprs;
  GPRSSerial->begin(19200);
  if (! client.init(*GPRSSerial)) {
    Serial.println(F("Couldn't find FONA"));
    while (1);
  while (!client.setApn(APN,USER,PASS));
  //float value = analogRead(A0);  // Reading analog pin A0
  float value = 10.0;
  client.add(VARIABLE_NAME, value);
  client.sendAll();
I’m sorry to have mentioned sim900 module, its actually sim800. But I found out there is no difference in code for the two.
This is the code I used. I used the new library as given in github. But still an error message pops up in the Serial Monitor.
Response of GPRS:
Response of GPRS:
Error with AT
Response of GPRS:
Error with AT
Response of GPRS:
@rahulbaburaj When you upload the code the gprs shield turn on any red led?
Metavix
Yes. A red light is always on. There is a blue and green light (The Status and NWK) which occasionally lights.
@rahulbaburaj and what pins are you using in the shield for tx and rx?
hi
you got any solution for that
Hi @akash,
In order to discard some kind of hardware problem, Can you try to do the official Arduino’s GPRS example and let us to know if it works for you (we attach you an example sketch)?
Sketch:
This sketch test the GSM shield's ability to connect to a
 GPERS network. It asks for APN information through the
 serial monitor and tries to connect to arduino.cc.
 Circuit:
 * GSM shield attached
 * SIM card with data plan
 Created 18 Jun 2012
 by David del Peral
 This example code is part of the public domain
 http://www.arduino.cc/en/Tutorial/GSMToolsTestGPRS
// libraries
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;        // GSM access: include a 'true' parameter for debug enabled
GPRS gprsAccess;  // GPRS access
GSMClient client;  // Client service for TCP connection
// messages for serial monitor response
String oktext = "OK";
String errortext = "ERROR";
// URL and path (for example: arduino.cc)
char url[] = "arduino.cc";
char urlproxy[] = "http://www.arduino.cc";
char path[] = "/";
// variable for save response obtained
String response = "";
// use a proxy
boolean use_proxy = false;
  // initialize serial communications and wait for port to open:
  while (!Serial) {
  use_proxy = false;
  // start GSM shield
  // if your SIM has PIN, pass it as a parameter of begin() in quotes
  Serial.print("Connecting GSM network...");
  if (gsmAccess.begin(PINNUMBER) != GSM_READY) {
    Serial.println(errortext);
    while (true);
  Serial.println(oktext);
  // read APN introduced by user
  char apn[50];
  Serial.print("Enter your APN: ");
  readSerial(apn);
  Serial.println(apn);
  // Read APN login introduced by user
  char login[50];
  Serial.print("Now, enter your login: ");
  readSerial(login);
  Serial.println(login);
  // read APN password introduced by user
  char password[20];
  Serial.print("Finally, enter your password: ");
  readSerial(password);
  // attach GPRS
  Serial.println("Attaching to GPRS with your APN...");
  if (gprsAccess.attachGPRS(apn, login, password) != GPRS_READY) {
    // read proxy introduced by user
    char proxy[100];
    Serial.print("If your carrier uses a proxy, enter it, if not press enter: ");
    readSerial(proxy);
    Serial.println(proxy);
    // if user introduced a proxy, asks him for proxy port
    int pport;
    if (proxy[0] != '\0') {
      // read proxy port introduced by user
      char proxyport[10];
      Serial.print("Enter the proxy port: ");
      readSerial(proxyport);
      // cast proxy port introduced to integer
      pport = (int) proxyport;
      use_proxy = true;
      Serial.println(proxyport);
    // connection with arduino.cc and realize HTTP request
    Serial.print("Connecting and sending GET request to arduino.cc...");
    int res_connect;
    // if use a proxy, connect with it
    if (use_proxy) {
      res_connect = client.connect(proxy, pport);
      res_connect = client.connect(url, 80);
    if (res_connect) {
      // make a HTTP 1.0 GET request (client sends the request)
      client.print("GET ");
      // if use a proxy, the path is arduino.cc URL
      if (use_proxy) {
        client.print(urlproxy);
        client.print(path);
      client.println(" HTTP/1.0");
      client.println();
      // if you didn't get a connection to the server
    Serial.print("Receiving response...");
    boolean test = true;
    while (test) {
      // if there are incoming bytes available
      // from the server, read and check them
      if (client.available()) {
        char c = client.read();
        response += c;
        // cast response obtained from string to char array
        char responsechar[response.length() + 1];
        response.toCharArray(responsechar, response.length() + 1);
        // if response includes a "200 OK" substring
        if (strstr(responsechar, "200 OK") != NULL) {
          Serial.println("TEST COMPLETE!");
          test = false;
      // if the server's disconnected, stop the client:
      if (!client.connected()) {
        client.stop();
        test = false;
  Read input serial
int readSerial(char result[]) {
  int i = 0;
  while (1) {
    while (Serial.available() > 0) {
      char inChar = Serial.read();
      if (inChar == '\n') {
        result[i] = '\0';
        return 0;
      if (inChar != '\r') {
        result[i] = inChar;
        i++;
